Inrush currents and solutions...... | Page 3 | on ElectriciansForums
Discuss Inrush currents and solutions...... in the UK Electrical Forum area at ElectriciansForums.net
Dobes_88
Surrey
Good evening!
Wanting to pick the brains of people more experienced in this field, approaching 2nd fix stage of an ongoing rewire where the client wants a shed load of lights throughout.
What particularly worries me is the hallway and kitchen grid switches where there’s around 10-12 lights operated by numerous switches in each area… And he may want a couple more lights added to it!
The plan is to fit fixed Enlite E8 downlights throughout but worried about the dreaded inrush currents, have emailed Enlite to see what sort of figures I should be expecting per unit but no reply as of yet…
Would a better plan to fit LED GU10’s to limit the inrush?
It’s all wired in 1.5mm, clipped direct with switch drops in oval conduit so will be able to get away with a C10 (if Zs in limits), but with the shear volume of lights (around 25-30 x per lighting circuit) I’ve read about these inrush current limiters that could be the solution - but I haven't or know of anyone that has installed them.
Any guidance would be greatly appreciated!
One cycle of mains current takes 1/50th second or 20milli seconds. In-rush currents may be very high but last for well under a milli second - that is much less than one mains cycle. There is very little power in a transient and heating effects can be ignored as far as cables are concerned so there should be no need to change any cabling. Traditional Z calc's don't work with transient currents because the effective frequency of the transient is 1000's of Hz so that is not much help and as electricity travels along wires at around 0.8 the speed of light or a quarter of a million kilometers per second the length of cable is not going to have much impact either. You also have to remember that tungsten, halogen and fluorescent lamps also have higher inrush currents - smaller peak but over a longer time. As LED lamps always need a driver (built in or external), it is the driver circuit that will determine the inrush current and these driver circuits contain far more sensitive components than a mains switch. Unless someone comes up with real measured transient data I don't see why you wouldn't work on the basis of 20 off 10W LED's per MCB circuit. By the time you have then broken down to 6 to 10 lamps per final switched circuit there is no problem. Changing from a B curve to C curve will only provide a factor of 2.5 over current capability. You would be better running off dimmers. I'm sure if LED's were a real problem they would be in scope for the 18th edition.
Just a little update, lights all up and running on a C10 MCB's (highest Zs being 1.1 Ohms) with no issues when turning multiple switches on at the same time.
Also had a response from Enlite for those interested -
"The inrush on the EN-DE8 is 0.6A PK measured in 100ms. We have tested 2-10 fittings on our AU-DPS400X dimmer module".
Thanks to all for your input!
Good. - & just FYI to help understand the range of these figures and how the method of measurement greatly affects to answer.. The 30W LED drivers which I mentioned in a previous post (Meanwell) where I had fitted eleven into one circuit, are individually specified at 55 Amps /500us. Hence since Meanwell use 1/200th of the time slot specified by Enlite and come out with a peak current nearly 100 times that you got from Enlite. (OK, a more powerful driver, but not by that extent). It illustrates the potential for problems though.
My putting the cat amongst the pigeons again...
The IET have a 200 A4 page Code of Practice for the Application of LED Lighting Systems (2014).
They also have a CoP - wait for it - for Low and Extra Low Voltage Direct Current Power Distribution in Buildings (2015) (only 60 A4 pages) that predicts we will all soon be distributing LV DC for lighting and electronics alongside normal 230 mains for high power devices and appliances - compliant with BS7671 subject to suitable sleeving and labeling - installing a second DC CU alongside the normal one.
Should be fun, eh?
One advantage its that it would get rid of the in-rush current problem for LEDs.
Should be fun, eh?
Using a driver which has a permanent feed and a control input will get rid of the inrush problem, without the need for an entire DC distribution.
I agree, that would be much better. However, 20 or 30 mains-voltage switch-mode power supplies located in ceiling voids must be more of a fire hazard and reliability issue than having one high quality DC supply for LEDs and electronic devices in the house. I am not push for this, just pointing out the way IET thinking seems to be going.
Many LED 'bulbs' have inbuilt 230 V AC conversters built inside them and they are by far the main cause of failure. The LEDs themselves now very rarely fail (some early high power ones did - and the higher the power the more they still fail).
I suspect you would still require an electronic power supply of some sort for each light fitting to drive the LEDs correctly as they will almost certainly need constant current rather than constant voltage supplies.
Reply to Inrush currents and solutions...... in the UK Electrical Forum area at ElectriciansForums.net
