Inspecting a campsite | on ElectriciansForums
  • Thread starter roukel01
  • Start date
  • Replies 8
  • Views 2K
Discuss Inspecting a campsite in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
R
roukel01
Hello All..
We look after a campsite which was wired some years ago to the 16th edition wiring regs, the site gets inspected once a year, the problem I have is that each hook up post contains 2 16a sockets but is protected by one RCD.
17th Edition now requires that each socket is protected by its own RCD, what should I mark this down as on my inspection report?? Would it be a "2" (requires Improvement) or a "4" (no longer complies with BS7671)
Your help/advice would be much appreciated.
Hello All..
My answer would be 4-Does not comply with BS7671.
Can also depend upon their site insurance company /Local authority requirements with joe public going on to the site whether it must be up to the current regulations.
I have a smiler problem with a caravan site that is due for a test, the company I worked for installed the system around 4 years ago with two sockets per pole (one feed) but the sockets are rcd protected so I am unsure if this is alright. Or do you need a feed to each individual socket
I agree with earlier answer as the 17th edition regs are not required to be implemented retrospectively and so this should be a code 4
Unless i have misunderstood your question, I suggest looking at your regs - special locations or techincal manual again, your allowed 3 x 16A outlets on a 30mA RCD at max.
So as long as each post has its own D/B then you dont have a problem
Hope this helps
If you want the page details from regs / tech manual i'll get it for you tomorrow;)
Hope this helps
REG 708.553.1.13 17th edition, "each socket outlet shall be protected individually by an RCD having characteristics specified in reg 415.1.1....."
Sorry but not sure where you got the 3 x 16A socket reg, I'm sure 16th edition allowed upto 4 sockets Per RCD, which has now changed.
I've now had a reply from the ECA regarding this query, and this was their response....
"the decision is ultimately yours, it could go under either code, As it was installed to a previous edition it complied with that edition. We are not at liberty to up grade every installation we work on, but we must ensure the work undertaken after the 1st July 2009 does comply. You can offer the upgrade to your customer to comply with the 17th but cannot insist they have it."
Reply to Inspecting a campsite in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Regulations notwithstanding, the only thing in those pics that is likely to be affected by sheep is the trailing flexibles on the ground from the...
