Inspection and Testing | on ElectriciansForums
Discuss Inspection and Testing in the Talk Electrician area at ElectriciansForums.net
134.2.1 During erection and on completion of an installation or an addition or alteration to an installation, and before it is put into service, appropriate inspection and testing shall be carried out by skilled persons competent to verify that the requirements of this Standard have been met. Appropriate certification shall be issued in accordance with Chapter 64.
Ok I know this but is it against the law put into service without certification.
As previously stated the statutory document is E&WR 1989. To prove you are complying with this document you would undertake visual inspections and testing.
Reply to Inspection and Testing in the Talk Electrician area at ElectriciansForums.net
That's a glass half full thought 🤔
2 3
During a new CU installation does the bonding for the gas and water also have to be upgraded to the latest regulations or just tested/ inspected?
