inspection and testing | Page 2 | on ElectriciansForums
Discuss inspection and testing in the Talk Electrician area at ElectriciansForums.net
Give the customer the EICR that you have deemed as unsatisfactory. Then if the customer wants you to,quote for the work to bring the installation up to a satisfactory condition. Only you know what will be required to make it satisfactory from the codes you have given so everyone on here will be guessing.
Reply to inspection and testing in the Talk Electrician area at ElectriciansForums.net
  • Solved
There is an article about that here: https://www.cement.org/learn/concrete-technology/durability/corrosion-of-embedded-materials It states...
FFS - popped it apart, found the same issue and thought I'd update... You guys were already there!
