Inspection Cameras | on ElectriciansForums
Discuss Inspection Cameras in the Electrical Tools and Products area at ElectriciansForums.net
Hi all. Just a quick post - Aldi's are doing inspection cameras for ÂŁ39.99.
I've had mine a couple of years and used it loads. Good camera for the price.
As an Amazon Associate Electricians Forums may earn a small commission from qualifying purchases.
I have a little Ryobi with the 4v Battery which was around ÂŁ40-ÂŁ50. Have also had a play with a more expensive one (can't recall which it was). The Ryobi is ok for all it gets used, but what I found common with both was it was it was a PITA to manoeuvre and direct them where wanted, I guess you get a knack for it but when only used 3-4 times a year I'll probably always curse the thing lol.
I have just bought one of the Aldi ones, not too bad but not excellent.
The picture is not as clear as I would like but the light is OK. I like the digital zoom, and that the battery indicator moves as you rotate/mirror the view
I do find that if you can get more light on the subject they start to be useful as direction is difficult and long distance viewing impossible without extra light. LED flexible strip or car running lights can be very useful to feed in beside the camera.
Ive just bought a bosch one as it uses the same 10.8v batteries as my little driver. It has a built in memory card so you can record videos or take pics.
It also has an 'always up' function where the screen image auto rotates so that you don't get disorientated if you twist the camera flex upside down.
https://www.bosch-professional.com/gb/en/gic-120-c-36677-ocs-p/
Bought for a specific job and only time will tell if i end up using again or not!
Reply to Inspection Cameras in the Electrical Tools and Products area at ElectriciansForums.net
J
SVP (grey water) gases leaking out - What do you see (pics)? Hi all, I would really appreciate your eyes on these pictures - What do you see ...
Jayp07
J
how often will you need to use it? Would renting one from a tool hire place be more cost effictive... and might give you an idea of good brands...
