I will do, thank you.Clearly from what you describe the installation is sub standard to dangerous. I think you should get someone to inspect and if necessary rectify anything dangerous as soon as possible. If I understand you correctly there is exposed live parts and this is a danger have no doubt about it. On that basis even with lock down we are able to attend as electricians where something needs to be made safe. Rather than trying to manoeuvre the conversation to a desired outcome I should go back to the people you report to and recommend what has been said to you, an inspection is needed.
Stay safe
good advice. I will do as you say.As a retired Electrician, obviously with I and T Quals, are you trying to justify what you have told someone, it should be obvious to that all is not well with this installation, and an EICR is the way forward, get the report done, add your findings and pass the documents on to the Church Authorities, or the person / persons authorising the EICR, as said earlier agreeing with your findings will be difficult without eyes on.
Why wasn't an EIC issued on completion of the work in the first place? Sounds like a DIY Dave has been used for the work to cut costs. Of course there is no proof of this, just an educated observation, for goodnees sake get the EICR done ASAP.
[automerge]1590403016[/automerge]
Thank youAs already covered above, what you describe appears to be inadequate/potentially dangerous but nobody can say more without seeing it (or photos at the very least).
If it is going to come to a legally worded letter demanding it is fixed, you wil need to have the written opinion of someone recognised as a "competent person" and that normally means a currently registered professional electrician.
If you still want more guidance to form your own opinion to direct the church authorities towards paying for that sort of written report (or approaching the original installer informally) then you would do worse than look up the best practice guides, in particular #4 on coding faults during an inspection:
https://www.----------------------------/professional-resources/best-practice-guides/
