Installation above suspended ceiling issues | on ElectriciansForums
Discuss Installation above suspended ceiling issues in the UK Electrical Forum area at ElectriciansForums.net
Kent
Hey guys
Got called to a job where the entire installation was fed above a suspended ceiling on a commercial premises wired a few years earlier. All the cables are draped across the ceiling grids, all light fittings not double insulated and made off poorly with the possibility for the grid to become live, all lights wired in a spaghetti junction on cabling, circuits overloaded and switched on caused mcbs to trip out in the mornings. No proper design whatsoever...was a complete mess. plus the grid wasn't earthed either...
I'm going to be ripping the lot out and starting again properly and doing the work via contactors. what system would you guys do? I was thinking of doing the work in plastic conduit in singles going to a few 10 way Klik outlet lighting distribution boxes then flexing off to the LED ceiling panels.
One issue I do have though, there is a fire alarm panel but all the alarms/sounders are located above the suspended ceiling grid. What actually happens with this? Its not a job I personally deal with but is this common? Its pretty redundant having all the sounders and detectors left above the ceiling, there is also no fire alarm call points either (smash the glass ones).
There is no emergency lighting in the building at all also which I cant get my head around, I will be doing this also.
Cheers guys
Why do the lights need to be double insulated? Why does the ceiling grid need earthing? What shape is the layout? Could you split the lighting up on to more switches so inrush isn't an issue? Ive just done an office where we installed trunking suspended on uni strut, Besa boxes bushed on for the lights close to the trunking and conduit teed of the trunking hung on studs with stud clips to the lights further away. Through boxes used with clicks and stop ends at the last lights. In the trunking was also the AC Cassette power etc. How big is the void above the suspended ceiling?
Lights not double insulated and cables draped across ceiling grid.
You are getting double insulated mixed up with insulated and sheathed . You are correct in that the brown and blue insulation should not be visible and suitably enclosed .
By all means rewire the lot . Or remake all the fittings off and secure the cabling with all round band
It certainly can be tidied but if you intend to put in place a new system is the ceiling grid staying because if so that can restrict whatever you intend to do.
Yea sorry guys I miss wrote the first post as double insulated lights, I meant double insulated terminations and in a enclosure.
This is just one aspect of cabling above the ceiling and there was much worse found above with multiple joints everywhere. there is also multiple wall lights/mirrors everywhere (its a bathroom showroom) so in other areas there is joints up to 8 cables in more going in all directions not within a enclosure.
The ceiling grid will be staying up and all I can do really is take down all the tiles and lights down one side of the room to run conduit/singles easily.
Reply to Installation above suspended ceiling issues in the UK Electrical Forum area at ElectriciansForums.net
    • Friendly
ok cheers for the help lads
This is an RSS feed of thread: Waste pipes above ceiling in new extension Content of the thread: Hi guys I have expressed an opinion on this...
