Installation cert went missing | Page 2 | on ElectriciansForums
Discuss Installation cert went missing in the UK Electrical Forum area at ElectriciansForums.net
Diode
My electrician had been filling in an installation certificate in a house and finished it. It was for a complete installation . He left it in the house which was still a bit of a building site. When we returned, the certificate had been lost by the customer. Does anyone have any suggestions on how I can certify saying that the customer lost certificate without having to re do the whole thing? It's about 25 circuits!!!
Stating the obvious I know but in all the books of certs I've seen there are 2 copies,one you rip out for client and the other stays in the book,why not just copy the info onto a new cert from the copy in the book?
Diode, you can call me nasty and suspicious (I am) but I don’t believe a word you say about the certificates going missing. The simple reason is they were never issued and you’re trying to cover your tracks.
Pay up for the job to be tested properly.
Well, if I was cynical, I'd agree with you and say that it was the op who carried out the work. Not because I'm nasty, but because previous posts have been about electrical work he has done and not really been sure about, such as whether to fit an RCBO to a dual RCD board he changed (and notified?).
If I was cynical, I'd say that he did the work, hasn't carried out testing, and wants to know if there is a way to convince LBC that certificates have been completed but lost, therefore it's all hunky-dorey.
What a good job it is that I'm not cynical....
As said you have to keep a copy of the EIC just in case the house catches fire or anything, you will need to prove to the court that you tested the house and not done what some on here do and just hope it all works!
If he has not kept a copy of the results then send your spark back in to redo the tests again - I would not pay him as he failed to complete his legal duties!
If as a company you dont keep copies of certs then try this one:
Call your accreditation body up and tell them you have been trading for x months/years and never kept a copy of an install certificate and post on here what they say!
Reading the posts I cannot help feeling that the original cert does not even exist but all said I started working with PCs 28 years ago and had it drummed into me about back up and always did yet fast forward to today and people are sloppy about this daft thing that there is a free MS utility called Briefcase on your PC/laptop so put all your stuff in a business folder then create a Briefcase folder on a memory stick then open it and copy and paste the business folder into it then at the end of the week plug in the memory stick right click the Briefcase folder and it will only update the files you changed .
Then put the memory stick in a safe place I put it on a nail inside a cupboard so if your PC/laptop breaksdown or is stolen you have only lost a couple of days work
Reply to Installation cert went missing in the UK Electrical Forum area at ElectriciansForums.net
Hello all easy cert users, ive been using easy cert since 2001 with no yearly subscription. and also found other people looking for older versions...
