installation enkin pdm250 dimmer modules | on ElectriciansForums
Discuss installation enkin pdm250 dimmer modules in the DIY Electrical Advice area at ElectriciansForums.net
jwellis
Scotland
Does anyone have any experience of installing Enkin PDM250 Multi-way dimmer modules? We have 4 dimmers at different ends of the kitchen / dining room, which have been wired two way (with 3 core cables). Each dimmer controls a different light in the kitchen / diner— Downlights, Over Island pendant, under wall unit LED strip and a pendant in the dining room.
We have power to modules, but nothing works when dimmer is pushed or turned to change the brightness. Assuming the modules are all working correctly and this is a wiring issue.
Could anyone with any experience of fitting this type of “intelligent” dimmer module help!!
Documentation from Enkin not great in terms of troubleshooting, so a bit stumped.
Thanks in advance.
Hi There
Did you manage to get the modules installed ok?
Reply to installation enkin pdm250 dimmer modules in the DIY Electrical Advice area at ElectriciansForums.net
Hi :) I'm currently renovating my outbuilding. My electrician has fitted 10 conduit LEDs (that support both leading and trailing edge) and x4...
Morning all, anyone had experience with BG touch dimmer like this one Touch Dimmer Switches - Intelligent Trailing Edge -...
