C
craig1000
If a install is not provided with a main isolator who should out one in?
Old install, no main switch, just the fuse then meter
Should i install one for the customer or should it be to request the DNO to install after the meter? The tails from the meter are more than 3mts long so it needs to be done if i have interpreted the regs correct?
