E
ElecEngineer
Can any one help..?
Having not installed any SWA before I’m about to undertake a job to install 6mm 2core cable to agarage. The cable would need to be buried for approx. 20m in the ground – whichI’m allowing to go 500mm deep. However it is when the cable first enters theground and when it comes out I’m concerned - remaining areas will be fixedevery 300mm onto concrete gravel boards etc – what mechanical protection would Ineed as it vertically enters and leaves the ground? To protect from strimmeretc.
Also I’m allowing for a IP65 rated garage consumer board withstandard sockets and switches - but are there any limiting factors ininstalling by windows and doors?
