Installation Reference Method | on ElectriciansForums
Discuss Installation Reference Method in the Electrical Course Trainees Only area at ElectriciansForums.net
East London
I have always been told/understood that the reference method for cables buried in plaster was reference method c (clipped direct), however I have seen reference made to reference method a (enclosed in conduit in an insulated wall). Does anybody have a definitive answer please?
page 318 to 323 of big green book, referance method A is cable in conduit within arcatrive or window frames, it is reference method C here is what it says it the big green book
[ElectriciansForums.net] Installation Reference Method
Hope this helps pal
This will also depend on the type of cable you are installing. If it is flat twin and earth, then it will be one of 101,102,103 or 104, look in the good book and see if you can work it out for yourself.
Cheers.............Howard
Reply to Installation Reference Method in the Electrical Course Trainees Only area at ElectriciansForums.net
