Discuss Installing 2 swa’s in the UK Electrical Forum area at ElectriciansForums.net
2 Ac units each rated at 40ampsWhy do you need 2 supplies for an A/C unit?
Ahh right 2 separate A/Cs that explains, sorry if I confused you.2 Ac units each rated at 40amps
OkAhh right 2 separate A/Cs that explains, sorry if I confused you.
interesting... you could say that 4cores of SWA, 2 for each circuit, is similar to running 4 singles in conduit.As I have been out of the game for a while can you run a single multi core SWA feeding two units from two breakers correctly labelled and then split at a box? Or is this not possible?
Apologies for the silly question its just out of interest.
good old crampets
Reply to Installing 2 swa’s in the UK Electrical Forum area at ElectriciansForums.net
