N
nocowboy
hi new to the forum i'm not a sparky but a bricklayer so not that clued up on electrics.I have just installed a new kitchen after being told by the sparky at work how too i have added another 2 new double wall sockets,to the main ring which was fine until the mrs changed the design round and wanted to put her dishwasher and washing machine under an additional worktop, this means the double socket will be beneath the worktop and will be behind the appliances so i presume it must have a isolation switch above the worktop, so to install an isolation switch to that socket what would be the best way to do it? and do you wire a isolation switch to the main ring just like a normal wall socket then spur of this to the socket as i need to put in another for the extractor fan ? also i want to install a outside socket to a brick built shed that is adjoining the house would it be ok to just spur of a double socket for this? sorry for all the questions
