Hi
I own a rented property which has just had it's pir. The electrician has said that it's recommended an RCD be installed. Since I'm semi qualified to 2330 lv3, I'm thinking of doing the work myself. If I was to replace a consumer unit, it would be classed as new installation which would require an Electical installation certificate right? The issue I have is am not fully qualified so I can't certifiy?
However I was told if I did the work then told someone to do a pir on the installation and it passed the pir then it would prove the installation is safe. All will be fine.
