Installing downlights in bedroom. | Page 2 | on ElectriciansForums
Discuss Installing downlights in bedroom. in the Australia area at ElectriciansForums.net
M
mihobb
Can you help me? I am about to install 5 12V downlights. I am not sure wether I need to use trunking in the loft or it is enough that I use thermal resistant cable and put it on top of the insulation. What do you think might be the best solution?
Is this a 1st fix? If so, I wouldn't even think about using 12v in a bedroom, why go to the expense of transformers? If you are worried about cables, you are just increasing the current in them by using 12v. If you have a choice, why would you concider running the cables beneath the insulation? LED v Halogen, you get what you pay for. If you want to pay ÂŁ2 for an LED light, they will be dim. Pay ÂŁ10 - ÂŁ15 they will be just as bright as anything else out there with the added benefit of the long life they give as well as the energy saving benefits.
Reply to Installing downlights in bedroom. in the Australia area at ElectriciansForums.net
  • Poll
Hi Folks, I'm looking for downlights that satisfy the following criteria: (1) white bezel; (2) fire-rated; (3) IP65 or above; (4) anti-glare...
I'm not sure on the environmental implications, a good quality integrated fitting will last many years and be more energy efficient than the GU10...
davesparks
