Hi all,
I have recently had a new hood installed and need to install some ducting. I live in a flat with loft access its a 1 up 1 down.
I'd like to run the ducting straight up into the loft and then out through the soffit. Can someone please recommend makes of vents, ducting to use? And also where to buy from.
Also, the engineer who installed the hood also installed the electric oven and gas hob. He fitted a plug on the end of the hood , oven and hob cables and plugged them into the wall ( I wasn't too impressed with what he did but he said it will be ok + he put a 3 amp fuse in the oven plug).
Is this safe to do this or do I need to install a fused spur?
