Installing earth rod | on ElectriciansForums
Discuss Installing earth rod in the UK Electrical Forum area at ElectriciansForums.net
P
Plonker 3
Cutting a long story short, I may need to install a earth rod soon at a domestic property but have never installed one before, I am more than happy to carry it out, I know about the regs side of things, but I would like some pointers as to what to look out for how to do it and any surveys that may need to be carried (like finding underground services etc) before I commence with the job.
It might be different in the UK but here the records of buried services are hit and miss. To play it safe we usually dig a hole about a meter deep then start whacking in 2.3 meter rods one after another with brass couplings. We test after the first four rods are in and formulate a plan from there depending on what readings we get.
go deep to be of any use (as in 2-3m min)
and don't mushroom the heads or you won't get the next rod or clamp on!
On a serious note, rarley have I had to go deeper than 4 foot here, infact only twice in the last year have I had to go 8 foot.
As also mentioned, dont mushroom the end, just incase you need to connect that second rod. (Good advice!!!)
Bit of a rush job, currently no earth at premises, had a extension built and certified 5 years ago said it was a PME but earth coiled up under DB :hammer:. Asked customer to enquire but may need to be done sooner rather than later unfortunately.
Interesting to see what readings were recorded on that certificate...
I know, just realised that it was a PIR they gave the customer not a EIC but still no remedials on it, makes you wonder what some people actually do with certs, even ticked the box saying Suppliers Facility for earthing arrangement.
4 foot?? lol!! And what sort of Ra values do you get with 4 foot of rod in the ground then?? I won't even ask whether you have checked on, or confident on the stability of those values, because unless your going into salt or brackish marshland it's unlikely you'll have any....
Reply to Installing earth rod in the UK Electrical Forum area at ElectriciansForums.net
I'm assuming the cable will have to be cleated well to hold it in place anyway, as a stuffing gland ain't going to hold it tight like a SWA gland...
2 3
