Installing electronics in wall cavity - Regulations? | Page 2 | on ElectriciansForums
Discuss Installing electronics in wall cavity - Regulations? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Due to the amount of light that is typically in a bathroom, how well would you be able to see the screen through the batter-lit 2 way mirror?
The mirror I am buying is specifically made to be used as a mirror TV. It is of a brand called MirroView. It comes in two versions depending on how bright the room is, the manufacture recommends the normal version for a bathroom.
I will receive two 5x5cm samples before hand to test both before ordering the mirror itself.
Reply to Installing electronics in wall cavity - Regulations? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Thank you, both. Seems like common sense may have prevailed, and the fellow is indeed going for one of the modern mirrors you mentioned...
G
Wall grout for shower Hi, Just wondering what the general consensus is with grout for a shower. I have epoxy grouted the floor but now that I'm...
Garfield28
G
