I've made progress on this, I've ditched the mechanical switch and gone for a Cartek GTS. This switches the battery 0V leg. It also needs a permanent supply and can switch up to 40A to use to control the ignition / ECU etc.
There is a fused 30A supply on the battery that feeds the under bonnet protection unit, if lifted this cuts the coil supply and a few other things. The only issue is that the hazard flashers come on when the supply is re-instated so needs a button push.
I have also identified the coil supply wire in the engine loom so if there's an issue I could use just that. The only minor thing is that the CarteK GTS would keep a permanent supply to the coil coil packs even with the ignition off. I could get around this by feeding the new coil supply via an ignition controlled relay.
