This thread titled "Installing Landscape panels without any gaps between rows" is posted in the under the Solar PV Forum | Solar Panels Forum on Electricians Forums.
after your last slate advise i bought 24 of them but fitters said to much hassle and leaded it!! its only money:)
Short side fitting, couple of reasons for not doing it, most wont allow it as in Europe (read Southern Germany) panels are expected to withstand 5400 pascals of load pressure (equates to about 6ft of snow load) REC will allow short side but it reduces load capability on their panel to 2800 pascals. The load is borne by the frame so a deeper frame with thicker material usually means they will allow it but not always. Most UK sites are unlikely to need 5400 pascals so its not too much of an issue, whats more of an issue is microcracking when the panels are supported at the ends the panel flexes across its length causing microcracking in the cells, it therefore increases recombination losses in the cells which means higher degradation rates for the manufacturers to contend with on their warranties also it lowers your customers yields so not a good idea!
i read all this senior members info and think SO MUCH TO LEARN! wind calcs!size of fixings in trusses!multi tracking!DNO!click fit!inverta choice!dti updates!deposit accounts NOW FRUIT PASCALS!!!! its all to much!!
We're all learning - all the time :-) that's what I like about the Forum. A bit of support when you've had a bad day (or fortnight at the minute!) food for thought about things you thought you knew and completely new trains of thought. That's what makes it interesting.
So dragging up this old post,
Hyundai can be clamped on the short side and mounted landscape on a standard Schuco rail system?
no worries, you had me worried for a second there as I knew we'd mounted on the short side a few times on the Hyundais, it's one of the reasons we like them so much.
Reply to the thread, titled "Installing Landscape panels without any gaps between rows" which is posted in the under the Solar PV Forum | Solar Panels Forum on Electricians Forums.
