Installing Nest 3 | on ElectriciansForums
Discuss Installing Nest 3 in the Central Heating Systems area at ElectriciansForums.net
Deepu Thomas
Can anyone advise on the right way to replace the danfoss tp9000 thermostat and ts2 sensor with the nest. I have attached pictures showing the current setup.
Thanks in advance,
[ElectriciansForums.net] Installing Nest 3
Live, Neutral and earth from the old programmer go to Live and neutral on the heat link. Terminate the earth in terminal block if no earth terminal is available.
Terminal 3 from the old programmer goes to terminal 6 on the heat link (Hot Water Call)
Terminal 4 from the old programmer goes to terminal 3 on the heat link (Heating Call)
To my knowledge, the nest doesn't use the ts2 sensor but if I'm incorrect, someone will let us know :)
neutral and earth go in the neutral and Earth terminals.
Live goes to the live and both relay commons (2 and 5)
The switched lives go to their respective N/O relay terminals (3 for CH and 6 for DHW)
The two wires from the thermostat (unless connecting wirelessly) go to T1 and T2 and are not polarity sensitive.
Then you carry out the usual electrical tests before turning it back on.
Reply to Installing Nest 3 in the Central Heating Systems area at ElectriciansForums.net
The point is that you set up a schedule of what temperature you want at what time and the nest brings the heating on at the right time to achieve...
davesparks
😂 No. If only! I've just dealt with a few different thermostats and programmers since my first in about 1970 🤪
  • exceeding voltage drop
    The cable is way undersized. If the voltage drop is detrimental to the installation I would make...
  • TT advise
    OK My take on the precautions to implement when omitting an up front RCD on a TT system. Tails...
  • SIL vs ATEX
    Good morning all, I have a question for those who are CompEx and SIL aware - I have various Ex...
