Installing new outside PIR light, do I need a switch? | Page 2 | on ElectriciansForums
Discuss Installing new outside PIR light, do I need a switch? in the Lighting Forum area at ElectriciansForums.net
As TJ Anderson said, I have confirmed there is a permanent live at the existing ceiling rose that I intend to take the feed from. It already has 3 sets of T&E connected ie loop in, loop out and switch drop. Is it still okay to connect another cable?
Yes, should be fine: you'll need to double up a couple of terminals, obviously, and make sure when you put the 4th cpc in the earth terminal that it's terminated properly and all 4 are held tight.
Thanks happysteve.
On having a closer look someone has already doubled up on the terminals so there’s a spare terminal on loop and neutral :thumbsup:
Thanks for your help
I was always taught that there should not be a switch connection inside an external light fitting....is this still the case ..is it stated in the regs that this is not in line with current regulations I personally never wired outside lights where there was a switched connection actually in the outside fitting as a bulkhead etc...a little off subject I know...just curious...thank you...
Reply to Installing new outside PIR light, do I need a switch? in the Lighting Forum area at ElectriciansForums.net
Hope everyone has had a great Christmas and here’s hoping we all have a better new year coming our way ! Remember our riches aren’t measured by...
Another tip for metal boxes, the single box version…. Is to fold flat the fixing lugs that you won’t be using… the top and bottom ones
Thank you so much for your help with this light work perfect now thank you again much appreciated
