Hello
Im looking at installing the Ring Doorbell Pro in the UK
I currently have a bell chime thats hardwired to the lighting circuit with a built in 6volt transformer. I understand that this is too low to run the ring doorbell pro.
I know it comes with a DIN transformer but this just isnt practical because of where the door bell wires are run too.
I was hoping to do one of two things
Would this work? I have been told that the Byron776 will power this. I don't really see how because this only works at 8Volt but the minimum is 16volt 1amp for the ring doorbell pro. I have seen on youtube people using Byron776 chime with built in transformer as for some reason it gives out just under 16 volt when tested as the ring push.
Has any one used byron776 and powered the ring door bell pro with no issues like buzzing, heat issues etc.
If the doesnt work i was thinking of removed the wires in the existing chime and running a power adaptor like https://www.amazon.co.uk/1000ma-Output-Power-Adaptor-Transformer/dp/B079T543BQ or https://www.amazon.co.uk/gp/product/B07GVRNW9K/ref=ask_ql_qh_dp_hza into the existing chime and connecting the cables to the two ring push cables. So effectively disconnecting all the power in the ring chime itself and just using it as housing will connecting the plugged in transformer to the existing ring push cables within the old disconnected chime.
Im just worried about power issues such as the plug getting hot as these two adaptors are running at 18volts an 600ma where i think the device needs 1amp will this cause it to over heat
As could i place the provided DIN transformer inside the existing door bell chime on its side as long as the cables are secure?
I can't place the transformer DIN housing because of where the existing chime and doorbell push cables are located
Any advice would be much appreciated
As an Amazon Associate we earn from qualifying purchases.
How about something like this, if you need 18v 1A.
Hi
Thanks for the recommendation. Do you think that will be fine to run the Ring Doorbell pro? Do you think it will get hot or buzz as I have heard that some running a plugin adaptor have issues with the plug getting hot and over heating also a loud buzzing which I think could just bee down to the fact that they have been using 0.6amp and not 1amp or 1.5
thanks
Hi
thanks
What does the spec for the door bell say it needs? You stated "..the minimum is 16volt 1amp for the ring doorbell pro." so I just put one up for that.
If you want one that is 1.66A then how about this one..
Daz134,
Daz134,
