insulation lump test | on ElectriciansForums
Discuss insulation lump test in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
G
Graham Coughlan
Could someone please help me understand insulation lump test. I've had a look through gn3 but i cant find anything that says "insulation lump test" as such.
Am i missing it or is figure 2.3 on page 39 pretty much it?
My final 2394 test is today!!
Cheers
Well been at this game for 20+ years and never heard of it.
Unless you mean the combined test.
Gn3 method 2
Disconnect main Supply and neutral.
Test between all line conductors and earth.
Basic really
The question ive got is: 19 - Four circuits have insulation resistances of 40MΩ, 50MΩ, 100MΩ and 100MΩ. When tested together (insulation lump test) what would be the expected reading:
been on a couple of sites where the scruffy gits have left a massive turd in the toilet BEFORE it's been plumbed in.
Not unusual for brickies on the lump, caught short? Oh ......not to be a plumber
We're all supposed to do a lump test now and again. But I've heard it's best done after a hot bath, and I don't think water and voltage mix well. Not that I fancy sending 500V through the boys anyway !
Reply to insulation lump test in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Continuity of the suspect cable appears fine all cores, from this I could work out the length of it and it really doesn’t appear looking at the...
I'd speak to an independant company about fixing this, you'd expect it to be a relatively simple adjustment and not require much in the way of...
davesparks
