Insulation Resistance - help please | on ElectriciansForums
Discuss Insulation Resistance - help please in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
G
Gazap
Could anybody please give me any help understanding my reading of IR, just completed a 2392 and testing a few circuits. I have a megger 1552 and testing at 500v
circuit 1 sockets (radial) tested L/E >299 , L/N >299 , then N/E 2.95 , then disconnected both ends from bar and had a reading of N/E >299. Is the reading of 2.95 to do with continuity at source ?
circuit 2 sockets (ring final circuit) tested L/N >299, N/E >299 then L/N 0.4 ? there is continuity between L/N but could not find out where ? there are 2 switched fused spurs but these are switched off and nothing is plugged in to other sockets. I then did a test of (L & N together) and tested to E, reading was >99.9 (tested at 250V)
circuit 3 lights (radial) tested with 500V and again (L & N together) and tested to E as there are floresent tubes and dimmers. reading of 113 Mohms with all the bulbs removed. is this reading quite normal as was expecting >299. Also could i do this test with the bulbs left in if connecting both the L & N together and testing to E ?
I know there are a few questions but cant see anything in any books i have ?
ok. your N/E of 2.95 is almost certainly due to the connections being left in the board. IR tests should be carried out with circuit totally dissed from any other circuits and supply.
your L/N of 0.4 could be the neons in the FCUs.
113 Mohm is a good reading. could be affected by the ballasts in fittings. always best to remove the loads completely before IR testing.
I know you said best to remove the loads(bulbs) but would it be acceptable to do a test with the loads if difficult to reach eg very high ceiling ? appreciate your help, many thanks
Exactly as Tel above as highlighted.
As you have done the 2392 you will have concentrated on doing testing as an initial verification, what your doing now are tests to a PIR. I personally would advise you to do the very first IR test at 250v as if you miss something, say a booster in a loft or even a bell transformer or an alarm system CCTV system then by putting 500v through them could fry and you could be not just embaressed but facing a costly mistake.
By doing a 250v test you would pick up the problem as a low reading, and investigate further, finding what was on the circuit and isolating properly. Then if you got good reading you could give it a 500v blast then.
It comes under section 612 of the regs, if you go to them you will see that it outlines the "soft" test.
On your schedule of results you will normally have 2 boxes if they are modeled exactly as the forms in the BS 7671-2008 for IR which is LIVE/LIVE and LIVES/EARTH, if your doing just the soft test as per 612 then you just fill in the one box LIVES/EARTH, which is often done on a PIR, where sometimes such as high bay lighting you can not isolate the loads.
On an initial verification though IIMO you should be well able to perform a full test.
yes was thinking more of PIR, on the NICEIC 'Schedule of Test Results' it is Live/Live, Live/Neutral, Live/Earth, Neutral/ Earth, will have a good read of 612, Many thanks
as an absolute amateur i would find it very helpful to revise the regs at home or whenever i get a spare minute , where can i pick up either a copy of them or a newly printed source ??
i know someone who brought a digital copy off ebay for a few pounds , i believe there is a new regs book coming out soon.
Reply to Insulation Resistance - help please in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Continuity of the suspect cable appears fine all cores, from this I could work out the length of it and it really doesn’t appear looking at the...
The instructions tell you to test the insulation and you already know from the result of the previous test that the L and N are not insulated from...
davesparks
