Insulation Resistance - help please | Page 2 | on ElectriciansForums
Discuss Insulation Resistance - help please in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
N-E Could be as previously stated because they share a common path and as they are in parallel then the total value will reduce, however i find this quite often not to be the case and it comes to mind from a call out yesterdy over a rcd trip.
common test between N-E bar showed ir value of 3.2Mohms after disconecting circuits neutral one at a time the reading clears when ring was disconnected traced to a faulty digibox hidden in a cupboard.
so the poor reading when taken from the bars showed up accross all circuits but was actually being reduced by one circuit alone and not a total resistance in parallel theory - just something to bear in mind as stated earlier best to test conductors seperately in my opinion.
ps: the rcd trip was traced down to boiler pump not the faulty digi box
Reply to Insulation Resistance - help please in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Continuity of the suspect cable appears fine all cores, from this I could work out the length of it and it really doesn’t appear looking at the...
That would depend on the instrument. On my old BM10 when you press & hold the button it just powers up the inverter circuits to generate the...
