Insulation resistance help | Page 2 | on ElectriciansForums
Discuss Insulation resistance help in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
The answer you are looking for is contained within GN3
To Pauldicker that's probably because the tester you were using had a max reading of>2000Mohms mine tester's max is >209Mohms
230M ohms is good for old wiring , but tell me what test equipment are you using to get 1200M ohms , i use Robin/fluke and I get max of 500M ohms only , over that is infinity ..
I am using a kewtech kt65dt 8in1 tester. I believe it goes to > 2000m ohms
thanks to those that have been helpful.
Gn3 does not tell you what to expect with older wiring. So some of the more derogatory comments are not helpful, as I said I'm still a newbie and I'm sure you were all at that stage once!
I do have GN3, however when I done my course everything was new and readings were always >2000 M ohms,
I'm just asking if these readings are about right for old wiring and when inspected by Elecsa will they allow the results.
Thats gotta be one of the best answers I've ever seen on here....this forum is now officially of more use than a guidance note.
It does give you the minimum required values for circuits operating at various voltages t​hough.
Having read a few,similar threads,regarding interpreting results,it appears to me,that some uncertainty,is injected,by trainees/newbees concentrating on "the" results,their chosen test device,displays.
A lot of them stick like glue,to a device they trained with,or were shown how to test with,initially.
This reluctance to swap,change or try other types of test equipment,occasionally causes a lack of confidence when deciding how results stand.
For example,some lads feel,a device which reads to >1999,and can give a reading of,say,805 Meg,is a better machine than one which reads to >300, even though we all know the limits in GN3 are at the other end...
Sometimes my own IR tester gives varying results.....i think i'll oil the handle bearings....:icon12:
CRIPES WHAT ARE YOU SAYING MAN! My old Metrel went to >1999 meg. My new Dilog only goes to >200 meg so the old one must be >1799 meg better!
Stands to reason innit?
my analogue fault finding megger goes up to a fart and a whisker past 50Meg. i know the 50Meg is OK, but nowhere in GN3 can i find a fart or a whisker. this is why you have to interpret the readings.
Reply to Insulation resistance help in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Thanks, I was hoping someone could confirm whether it was odd or not. I've done a fair bit of insulation testing but only on a small number of...
There can be a few reasons for low L+N -> E readings: Connected equipment is leaking. By design, or just old/damp SPD are connected (but there...
