insulation resistance of a 3ph circuit in 2391 | on ElectriciansForums
Discuss insulation resistance of a 3ph circuit in 2391 in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi guys, another silly question, how to measure the insulation resistance in a 3phase circuite? shall i do it in 2 steps?
1: between cu and isolator/starter.
2:between isolator/starter and 3ph socket
cheers
Turn off power.Simple installations should be checked as a whole.test to earth from all live conductors including neutral connected together.or each live seperatly to earth.when you have vulnerable circuits i.e.. dimmers etc.i think.
hi, i am still bit in dark, when i test continuity of a 3 phase circuit i should test seperately between cu and isolator; isolator and socket, then add up, but when testing insulation why should i test it as a whole?
please enlighten me!
Hi Bluesky,
You don't want to be doing it circuit by circuit - you'll be there 'til the following day:)
The procedure is simple.
Sub board main-switch open.
Motor isolator open.
Dimmer bypassed.
FCU bypassed.
All other switches closed.
Three phase board - all MCBs closed. Main switch open.
Select 500v range and perform ten point test.
i.e.
Place probe 1 on earth bar and probe 2 onto - L1.....L2.....L3.....N (4 tests)
Place probe 1 on neutral bar and probe 2 onto - L1.....L2.....L3 (3 Tests)
Test L1 - L2, L1 - L3, L2 - L3 (3 Tests)
NOTE: L1, L2 & L3 are tested on installation side of 3-phase main switch.
Then:
Test from motor isolator to motor (or 3 phase socket)
Test single-phase sub-board circuits individually (due to RCD) - should be two circuits - don't forget to throw the two-way switch to test your strappers.
Job Done:)
Don't think I've forgot anything.
PS
The 2391 board will be TN-S, if you had a TN-C-S supply you woulld have to remove the neutral test link otherwise you would get continuity between neutral and earth.
You need to break the neutral link on any TN system - TN-S included - for the purposes of an insulation resistance test.
Hi Risteard,
I understand your reasoning, but I didn't on my 2391 and the assessor didn't say anything.
We weren't told to do it during the course, either.
Ironically, I got >299 M Ohms on my N-E test, but I do know why you're saying you should disconnect.
I can't understand why it didn't show up the fact that they are connected on the test. Any ideas?
It's alright, it's just come to me.
The 2391 board had a seperate 'main isolator' which was probably 4-pole.
When the assessor opened this, it will have disconnected the neutral as well:)
You beat me to it. I suspect that is what has happened. When I did it we certainly had to break the link.
im doing am2 on tncs do i have to remove the main neutral out of bar or take each one out and on my lighting circuit do i only flick the switches on whichever phase its on thanks
On single phase installations, the main switch will be double pole.
As such there is no requirement to disconnect the N-E link.
Reply to insulation resistance of a 3ph circuit in 2391 in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Thanks, I was hoping someone could confirm whether it was odd or not. I've done a fair bit of insulation testing but only on a small number of...
Continuity of the suspect cable appears fine all cores, from this I could work out the length of it and it really doesn’t appear looking at the...
