Insulation Resistance of floodlights | Page 2 | on ElectriciansForums
Discuss Insulation Resistance of floodlights in the UK Electrical Forum area at ElectriciansForums.net
Davetherave
I keep getting short circuit between live and earth. I can't work out wether this is normal or a genuine fault. Unfortunately I can't lower the floodlight to inspect further. Can only test at the bottom of the base. Can any one help?
This is daft. We're 26 posts into a thread called "Insulation resistance of floodlights" and the OP still hasn't told us what the insulation resistance of his floodlight is. It could be anywhere between 0.14 ohms and 0.14 megohms, which is the same ratio as that between a pint of beer and 24 articulated tanker lorries of it.
0.14 ohms
OK, how are you measuring this 0.14 ohms?
Is the floodlight connected to the supply cable while you're measuring?
Is it connected in parallel with several other lights?
Where exactly are you connecting your test leads to?
What's the Zs of the supply at the base of the lamp column?
What type of lamp is it?
0.14 ohms
Well if it's really 0.14 ohms L-E and the light works, the CPC must be O/C somewhere and there is a risk of exposed bits being live. If this is not obvious to you, I suggest studying a bit more about testing before undertaking this kind of work.
OK so you walked over to a random floodlight that was WORKING and thought hummmm im going to do an insulation resistance test on this working light????
WHY MATE ???
Alternatively if you are part of the electrical trainee Nerd Herd then leave the flood well alone and let it continue working normally as it is before you do F it up !!
Reply to Insulation Resistance of floodlights in the UK Electrical Forum area at ElectriciansForums.net
I may have been mistaken regarding TT I will look into that, thank you for the valued reply, but in general I stick to my post, a good topic for...
There can be a few reasons for low L+N -> E readings: Connected equipment is leaking. By design, or just old/damp SPD are connected (but there...
I was at the other end of the results spectrum today. As I was driving home I had a call from my "Mrs Richards from Fawlty Towers" lady, very deaf...
My bafflement increases. I swapped the offending light with one elsewhere on the back of the house - one of those that's on a circuit of its own...
He is after the four options for 1 and 2 of the multiple choice exam, probably optimistic someone will know this. Your question 3 in incomplete to...
