M
mikemack00
Hi
Was wondering if you could clear up a few things I on't quite understand, I've been told it is possible to do an insulation resistance test on a live DC cable (Solar pv) by testing to ground. Is this right, and what voltage rating should I set the megger to?
Also on a domestic solar pv installation would you test to earth on the consumer unit?
Also how is the voltage given out by the megger affected by the voltage in the circuit? and vice versa.
Confusion reigns:mad2:
