Insulation Resistance query | on ElectriciansForums
Discuss Insulation Resistance query in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Amp David
Mentor
Glossop
Just at a job this morning where customer has an RCD that trips whenever it likes with no pattern in when it trips.
Testing lives to CPC found that RFC was showing 10.5 Meg ohms which as opposed to >299 for all other circuits. The only item of equipment that wasn't unplugged due to location of the socket was the Sky box in the bedroom.
I then managed to get the drawer unit pulled forward to unplug the said Sky box then re tested and got >299Meg Ohms. What puzzled me was how can an item of equipment which is double insulated affect Ins Res readings between Live conductors and CPC?
Faulty plug/lead?
Have you IR tested the plug/lead?
+tion:
I was thinking if its got a 2 core power lead.
Is the SKY box still working after you put 500vdc across it ? if then you were lucky also you say the RCD trips anytime I had a job like this and I mentioned to the customer I cannot find the problem so you need to take note of what you were doing when it tripped and a week later I was told it was the dishwasher.
Course its still working, why wouldn't it be.
Told them the same, that all fixed wiring was ok so will have to keep an eye on what is being used etc.
The aerial coax lead is likely to be grounded to provide a screen for the signal line. A signal ground rather than an electrical ground. This maybe where you are getting lower than expected readings.
must be the leakage fairies. don't forget that the neutral is connected to E at source ( TNC-S ) so that could affect your reading .
so, it's back to the fairies then. unless it's the coax, as said previously.
Reply to Insulation Resistance query in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Thanks, I was hoping someone could confirm whether it was odd or not. I've done a fair bit of insulation testing but only on a small number of...
Continuity of the suspect cable appears fine all cores, from this I could work out the length of it and it really doesn’t appear looking at the...
