Insulation resistance test on a EICR/PIR | Page 2 | on ElectriciansForums
Discuss Insulation resistance test on a EICR/PIR in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
this is pic 1 as per my original post
test carried out with L/N joined to Earth and no need to disconnect loads/vunerable devices
pic1 to test whole insulation, shows link between L/N (incoming) at main switch with supply isolated.
Q. if linked on incoming side of main switch and switch is off, then i wouldnt be testing pass the switch, would i? also if linking on incoming side then i am working live?
This drawing is wrong as you say you are on the incoming side of the switch where 99% of the time is live due to no local DNO isolator being available in this case I have made up a jump lead with croc clips on it and yes the main switch should be off and even then you need to test the dead side to confirm it is safe
Reply to Insulation resistance test on a EICR/PIR in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
That would depend on the instrument. On my old BM10 when you press & hold the button it just powers up the inverter circuits to generate the...
Continuity of the suspect cable appears fine all cores, from this I could work out the length of it and it really doesn’t appear looking at the...
