Insulation resistance test on a whole consumer unit?HELP | Page 2 | on ElectriciansForums
Discuss Insulation resistance test on a whole consumer unit?HELP in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hey all, Ive noticed alot of you are fixated and worried about pumping 500v through a consumer unit with fear of damaging elerctronic equip. In most cases for newly built electrical installations all volt sensitive equipment/IT equipment are capable and designed to withstand 500DC. If you just want to be on the safest side simply switch off mcbs that are connected to such equipment and perform your IR test as normal from output side of Main Switch.
Reply to Insulation resistance test on a whole consumer unit?HELP in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
That would depend on the instrument. On my old BM10 when you press & hold the button it just powers up the inverter circuits to generate the...
Thanks, I was hoping someone could confirm whether it was odd or not. I've done a fair bit of insulation testing but only on a small number of...
