So what was the reason Tel?
My initial thoughts were to disconnect but being that we were in a school it was difficult to leave doors unlocked while I got a wrench.
Does anyone have any experience with these Schneider MCCB boards you install the MCCB and tighten it and the head snaps off can you get these MCCB's out again and reinstall?
Had it been energized previously or were you doing the initial test? If you were, as you obviously know, that shows up a good reason for initial testing ......if not, someone slipped up badly, as you also know. It's a bit rough, though...…...or rouge, as one well known poster might say.Ive seen similar on a new install on a treatment works. Turned out that a thin piece of masking type tape had been put across the top of the isolator (to avoid anything dropping in I suppose) which hadn't been removed when cable was installed. It tracked just enough to give a less than satisfactory IR reading but not enough for dead short.
