Insulation resistance test | Page 2 | on ElectriciansForums
Discuss Insulation resistance test in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Westward I've been on this forum so many years I hardly post but read a lot of here and have to say u are one of the most helpful I've come across thank you mate appreciate your replies
Thanks for that much appreciated.
Going back to the IR question. You could do a global test and if the reading is too low then knock a circuit off 1 at a time until the reading improves. You can then hopefully have Better idea on what circuit is providing the low reading. Once you have narrowed that circuit(s) down you would need to test L to E, N to E. which ever one comes out low is your problem. At that point you will have to investigate more by inspection
Reply to Insulation resistance test in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
That would depend on the instrument. On my old BM10 when you press & hold the button it just powers up the inverter circuits to generate the...
Thanks, I was hoping someone could confirm whether it was odd or not. I've done a fair bit of insulation testing but only on a small number of...
