insulation resistance test | Page 2 | on ElectriciansForums
Discuss insulation resistance test in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
both. as durham says. MCB off, test across MCB load side and earth bar. that's L/E. N/E with cables in neutral bar will read all circuits commom th that neutral bar, so switch off all MCBs before testing. in fact, i would perform IR tests with the main isolator OFF.
if you clip onto the neutral bar does doing this send a voltage down all circuits, if it does then to test individual circuits i will need to take the wires out, is that right?
thank you again your post came through while i was writing this.
Reply to insulation resistance test in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
That would depend on the instrument. On my old BM10 when you press & hold the button it just powers up the inverter circuits to generate the...
Thanks, I was hoping someone could confirm whether it was odd or not. I've done a fair bit of insulation testing but only on a small number of...
