insulation resistance testing | on ElectriciansForums
Discuss insulation resistance testing in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
J
john h owen
When carring out a Insulation Resistance Test on a 3 phase motor Circuit do you test the motor itself too or only the supply cable to the motor or is it the same as other circuits disconect the motor because it is the load?
After the test what Final Safety Considerations should you have?
Just test the supply.
Be aware that when you reconnect the motor that the supply is switched off, so as to not start the motor when you are close to it.
Reply to insulation resistance testing in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I may have been mistaken regarding TT I will look into that, thank you for the valued reply, but in general I stick to my post, a good topic for...
There can be a few reasons for low L+N -> E readings: Connected equipment is leaking. By design, or just old/damp SPD are connected (but there...
