Insulation Resistance zero Ohms | Page 2 | on ElectriciansForums
Discuss Insulation Resistance zero Ohms in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
Last time I had something like this this it was a spur in the loft running a tv signal amplifier.
It took a while to find. The extremely good natured house-owner was looking at my tester and asked ask if we could send 1000v through whatever it was and track down the smoke!
As above, try a continuity test to get a better sense. If you have a socket adapter for test leads you can hunt it down as the closer you get to it the lower the resistance should become.
Thank you all so much, I've learned a lot and actually found what the problem was. It was a fused spur feeding a burglar alarm system. Thanks to everyone who took the time to reply.
Well done. Very satisfying when you find it!
Well done.
p.s. See post 5!!!
Reply to Insulation Resistance zero Ohms in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
Continuity of the suspect cable appears fine all cores, from this I could work out the length of it and it really doesn’t appear looking at the...
That would depend on the instrument. On my old BM10 when you press & hold the button it just powers up the inverter circuits to generate the...
