Insulation Resistance | on ElectriciansForums
Discuss Insulation Resistance in the DIY Electrical Advice area at ElectriciansForums.net
Scotland
As an adult learner I understand that any equipment connected to a circuit that may be damaged by the IR test voltage should be disconnected. I watched an electrician carry out an EICR on a property I rent. On a ring final circuit he removed the plugs fom the sockets before carrying out the tests. If the socket is switched off why does he need to remove it? Thanks in advance.
Not all sockets isolate both the live and neutral when you turn the switch off
Many just isolate the live leaving the N connected.
So the electrician was doing his testing correctly by both protecting anything that was plugged in and by removing possible sources of resistance that may influence the test.
Reply to Insulation Resistance in the DIY Electrical Advice area at ElectriciansForums.net
Thanks, I was hoping someone could confirm whether it was odd or not. I've done a fair bit of insulation testing but only on a small number of...
There can be a few reasons for low L+N -> E readings: Connected equipment is leaking. By design, or just old/damp SPD are connected (but there...
