Insulation Resistance | Page 2 | on ElectriciansForums
Discuss Insulation Resistance in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi
You are Lucky i get 0.00 on all three are you using Kewtech KT61
Mark
Try a kt35 ! better for ir testing as you can use the 250v function !
got the same yesterday and was using a KT61 L/E 5.3MEG N/E 5.3MEG L/N 0.00 will dig the prob out today and let you know but prob as said something still connected or loose connection :D
Agree IR testing is biggest pain it is worth doing 250v test first saves blowing anything or link L+N
Regards
Kung.
Reply to Insulation Resistance in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
If the main switch is on when testing global IR then the neutral and earth will likely give a very low reading. Not that anyone would...
loz2754
L
Continuity of the suspect cable appears fine all cores, from this I could work out the length of it and it really doesn’t appear looking at the...
