B
Buzz-light-bulb
I'm fed up of having to disconnect all conductors out of the rcbo's to obtain an insulation resistance test, does anyone having a better solution to bypass this to make life easier.
Discuss insulation resistance in the UK Electrical Forum area at ElectriciansForums.net
Why are you having to remove them?
You little genius, oh hang on you'll also need one of those needle like probes to get to the screw… damn
I like youI have never had to remove them as have a set of thin entry probes, fluke do them, I always use them. I thought I was missing something obvious, but it was just a case of your probe is to big for the hole!
Read 612.3 'i' of the regs 'pre test checks'.
Reply to insulation resistance in the UK Electrical Forum area at ElectriciansForums.net
