B
Buzz-light-bulb
I'm fed up of having to disconnect all conductors out of the rcbo's to obtain an insulation resistance test, does anyone having a better solution to bypass this to make life easier.
Discuss insulation resistance in the UK Electrical Forum area at ElectriciansForums.net
Read 612.3 'i' of the regs 'pre test checks'.
What if I use an off cut 2.5mm conductor linking it to L - N terminals connected to croc clip and other croc clip to earth bar, or would i get a false reading due to the rcbo
I understand the discrimination offered by rcbo's but you can always turn each circuit off to see which one trips the rcd.
rant over lol
Unless it's a neutral fault.
Reply to insulation resistance in the UK Electrical Forum area at ElectriciansForums.net
