Discuss Insulation tape on connector blocks in the UK Electrical Forum area at ElectriciansForums.net
Buffalo Bill job imoIs it necessary to cover the connector block in insulation tape when live connections have been made into a connector block?
nope. block should be enclosed in a suitable enclosure such as a wagobox, with the outer sheath inside said enclosure. i.e.no basic insulation outside.
definitely not OK. how could anyone know there was a cable vertical from that box, once it had bee tiled over.Is it ok though as long as they’re stuffed inside a disused knockout box and tiled over? Found on a recent kitchen rewrire. ??
View attachment 61258View attachment 61259
I had that a couple of years back, except they’d skimmed over it and left the live touching the back box so every time the poor woman washed the walls she got a belt...Is it ok though as long as they’re stuffed inside a disused knockout box and tiled over? Found on a recent kitchen rewrire. ??
I would also question their logic of tiling over it in the first place ...
Could have just stuck a double socket on it and had an extra power point
That takes a special degree of ineptitude ?
Reply to Insulation tape on connector blocks in the UK Electrical Forum area at ElectriciansForums.net
