Insulation tape on connector blocks | Page 2 | on ElectriciansForums
Discuss Insulation tape on connector blocks in the UK Electrical Forum area at ElectriciansForums.net
If it’s easily accessible I thought a cocky block was acceptable? I just wasn’t sure the reason we tape over the terminal block as all live conductors are terminated and the block is plastic?
If it is accessible then yes, a chock block or “cocky block?!!” Is just fine.
Tape is not required in my opinion
If a terminal block is not adequately enclosed to provide the necessary protection, a bit of PVC tape is not sufficient to complete the job. OTOH if it is adequately enclosed, the tape won't add anything. FWIW there are very few places where PVC insulating tape is actually useful for insulating. It's useful for all sorts of other things though.
It’s good to tie the Mrs up very robust and strong 5 tight wraps and she’s going nowhere ??
Enclosed in a jb or electrical panel?
Yes, you can't just leave it lying about. It's got to be in an enclosure with suitable IP rating for the environment, that provides strain-relief for the cables. Ideally the terminal block should be fixed to the enclosure and, if the enclosure is metal, of such a design as to provide adequate creepage and clearance distances from the terminals.
choc blocks are screw connections and such should be accessible for maintenance & testing in the future. Do not bury in the wall where nobody will know they are there. All cable runs must run horizontal or vertical from accessories to accessory.
So what is the reason people tape them just a question. I work On industrial equipment i.e motors and starters. Modifications are common and are made in the electrical panels but I had someone mention to me about taping all chick block connections but don’t see the point if they are in an enclosure.
You are right! I think it’s belt & braces just an extra layer of protection in case some odd wire may touch one of the screw terminals or to hold the cable in place with the missing cable grip.
Well, we've had cocky blocks and chick blocks now. Don't remember those in the regs!
OOI, what cases are there where it can actually be used for insulation? Seems like a name change might help a little with the common misconception. I do see it called Electrical tape in some places, though not sure that helps much.
Reply to Insulation tape on connector blocks in the UK Electrical Forum area at ElectriciansForums.net
Thanks, I was hoping someone could confirm whether it was odd or not. I've done a fair bit of insulation testing but only on a small number of...
Tape for pipe insulation Does anyone have recommendations for tape to seal the seams in foam pipe insulation? Most tape seems to get brittle over...
siricosm
