OP
Maxstone89
That reg states identification by colour and states nothing like sleeving has to be used ect.
Discuss Insulation tape in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Cable ID Markers (Try Farnell they do a 250piece kit for £50 odd)
Heat Shrink
Don't use tape, it looks naff and is not the proper way of doing it.
As for the sleeving falling off, how did it come off? If the cable is tightened inside the terminal, it is impossible for it to come off without being cut off, or the cable coming loose and then it falling off.
Which leads me to another point, if it falls off, you are using the wrong size sleeving.
Hope that helps
sleeving goes all the way around the cable.I find it hard to believe nobody else has ever had sleeving fall off a wire. I've had it happen loads of times, not just where I'm installing it and have been given the wrong sized sleeving (when you're working for someone else you use what you're given) but where I've gone to make adjustments to other people's work. It happened on Friday when I was changing a lighting battery.
I don't see the problem with tape either - if you wrap enough around the wire then it's not going to fall off, but that said I've seen far too many supposedly experienced electricians actually not knowing how to wrap tape around a cable to pull it in - instead of stretching it to make a tight fit they just loosely wind it around and rely on the stickiness of the tape. After the cable comes off the draw wire for about the 3rd time I usually tactfully suggest I have a go instead.
Reply to Insulation tape in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
