E
er06
Recently while I was testing a newly constructed building, I found that insulation tests failed for some circuits.
In a 3 phase panel;
1) Phase to earth insulation test shows the value around 1.2 M ohm.
2) In the same circuit Phase to neutral shows 0 ohm.
But for most circuits, got the expected values (>500 M ohm).
While those panels are powered up no tripping fault occurred. Even the insulation failed circuits are working properly.
What could be the reason to get those values for some MCBs?
Thanks in advance.
In a 3 phase panel;
Thanks in advance.
