Insulation test, Meggering. Do they often fail? | Page 2 | on ElectriciansForums
Discuss Insulation test, Meggering. Do they often fail? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Should have the neutral open circuit, that would stop the combined and that neutral and earth are the same point at the transformer, the centre of star system
P1-P2, P1-P3, P2-P3, P1-N, P2-N, P3-N, P1-E, P2-E, P3-E & N-E
after that its logic to find where the break down. Is look on the faulty line for any loads
Reply to Insulation test, Meggering. Do they often fail? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi James, At the inverter end the multi strand is ferruled and torqued in the terminal and at the motor end they are the “wago type” push fitting...
