drummonkey
Hello to you all, and apologies for another question on this topic but I'm new to all this and completely stuck!
I've been testing a Ring Final circuit today with a Megger MFT and got a bizarre reading on one of the IR tests.
On the continuity test I seemingly got correct readings on all the tests, however I never tested Neutral to CPC at the time.
Then when I came to do the IR test on the ring everything was proceeding as planned until I tested Neutral and CPC. The meter just reads 0, not even a smidgen of a reading, am I right in assuming that there is a short between neutral and cpc?
When I then went to find the problem using a continuity test with outgoing Neutral and incoming CPC connected together and vice versa, I gradually get smaller readings towards one section of the ring, so is this where the problem is located?
I also noticed that in most of the sockets, I didn't need to turn the socket on to get my continuity readings whereas I'm sure I did for the Live/Cpc tests, is this indicative of the fault also.
Thanks so much for your assistance, apologies for asking and look forward to your replies
Alan
Alan
