Insulation testing problems | on ElectriciansForums
Discuss Insulation testing problems in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Redditch
Hi all, if I’m getting an insulation reading of 0.03 across N & L on a lighting circuit what would cause this? Neutral earth, live earth, are in the acceptable realms.
Well for practical purposes that's a dead short so you've got a dead short or a lighting fixture still in place. Could also be a neon indicator if you've lights on a neon switch such as outdoors - or a PIR sensor as well.
Is it sufficient just to turn the neon FSU off and test? Found one in the loft
Reply to Insulation testing problems in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
If the main switch is on when testing global IR then the neutral and earth will likely give a very low reading. Not that anyone would...
loz2754
L
I was at the other end of the results spectrum today. As I was driving home I had a call from my "Mrs Richards from Fawlty Towers" lady, very deaf...
Recommended Sponsor News
thanks for the clarification. ( also thanks to Dan. ).
More info on link below http://sbsc.uk.net/
9K
Happy Friday Everyone! Subscribe for more jokes direct to your mailbox or send us your own jokes to be in with a chance of featuring, by clicking...
6K
